I received the EVO from Tony last week. Now Im ready to start hooking it up to the Mogul. I have two options: 1. I can use the circuite board in the LGB but Tony said I would need to use an 18 volt battery. 2. avoid the circuite board and rewire and then i can use the 14 volt battery. I can do either options but would rather go the easiest route. Here is what Im looking at. The first picture is the drive from the mogul. What wire goes where?
Next is the circuite from the cab area. What wires are for the smoke. I want to get rid of the smoke unit?
This is the tender area. Everything is going to be stored in here. Im using the Li-ion batteries.
This is what im working with. I plan on using my controler from the live steam forney. That is a Planet controler. I assume I need the receiver with the EVO.
I have an idea on how to wire but before I start taking wires out ect… I just want to get an idea on what would be the best way. I would like to use the 14 volt battery but if using the circuite board is easier then can go that ruote.
