I spent the morning trying to find the best way to make some link and pin couplers for my hartland mini series rolling stock. (I hate the hook and loops). I wanted to avoid buying them because Im too cheap and broke. AFter a while I came up with this. I took a piece of wood abou 1-2 inches long drilled a hole and mounted that to were the old hook/loop coupler was. Then I drilled another hole on the other end for the link and pin. Ithen took a saw and cut through the middle for the link to fit into. The I took some old bike chain and took the links off. Thats my links. Of course the pin is a cotter pin. I also rounded of the ends. I really wanted to use metal but I could not find anything that was easy to work with and mount. I had to settle for wood. Now all I need to do is smooth it out better and paint it to look like metal. Any ideas ???
