this is a pile of Flats
I think I counted 11 of them in all…WST has them for less than $16 each, so I’ve ordered a couple of times to get what you see above. I am interested in building them up to be used with my Porters, American, Up-sized Annie and Climax. You may remember this discussion-Climax Consist: http://www.largescalecentral.com/LSCForums/viewtopic.php?id=8559 Then You have the most recent activity from Ric: http://www.largescalecentral.com/LSCForums/viewtopic.php?id=10102 and the Tanker redo: (got one kit on-hand) http://www.largescalecentral.com/LSCForums/viewtopic.php?id=10173 In addition to above I am thinking of doing: a MOW Caboose like this…well as best as I could do it! Though it’d be pretty narrow. Using the idea from Kevin when he built the little work caboose “1/2” in GR a few years back.
or something like this on the flat to have a “work area” http://www.trains.com/grw/objects/pdf/logging_-_caboose.pdf then there was the GR article about using the HLW Flat to build up a Gondola…may consider that as well! April 2007 I believe I’d like to install the body mount KD “1” couplers on my equip to sim the 3/4 style…thoughts? ramblings? ideas? snide comments? Happy New Year! cale
