I managed to fry the fuse on the BTK. Um, BIK, um, that thingy that the charger plugs into.
What size fuse is it?
Depends on the BIK.
If it is a BIK-TC5 it is 5 amps.
Tony, should he not check out his wiring before just sticking a new fuse and powering up? I sure would, fuse is a sftey device and will go before a board goes!
Hi Paul.
Perhaps he should but it depends on why the fuse blew.
Tony, it blew because there was an excessive current!!! And just what would cause that, pray tell?
Paul
Ol’ Stupid here threw the switch in the SD-45 from battery to track without disconnecting the battery car or turning off the BIK. There was a sudden influx of 18 volts at 10 amps. The fuse worked as designed.
Thank you Steve.
Brain fade can happen to any of us.
The trick is owning up to our mistakes.
TonyWalsham said:What a great quote! and so true!
Brain fade?
So it wasn’t a senior moment? I’m so relieved. I thought I was loosing it.
Steve Featherkile said:I thought amps were produced when something is using the electrons. What was on the track sucking the amps?
Ol' Stupid here threw the switch in the SD-45 from battery to track without disconnecting the battery car or turning off the BIK. There was a sudden influx of 18 volts at 10 amps. The fuse worked as designed.
John Bouck said:A slug crossing the rails? Salt the rails!Steve Featherkile said:I thought amps were produced when something is using the electrons. What was on the track sucking the amps?
Life is what heppens to you while you are making other plans.
tac
John Bouck said:Yes, John. Gees, are youse guys writing a book?Steve Featherkile said:I thought amps were produced when something is using the electrons. What was on the track sucking the amps?
OK, so I finally found a fuse of the same physical size, a 5 amp, 125 volt fast blow, sold for Christmas tree lights. I guess that will work? The others were 'way expensive, designed for microwave equipment.
If it is the same physical size and the same amperage rating then you are golden. Voltage is irrelevant on fuse ratings.
