Alright I’m working on my first large scale building and I need help. Not new to trains just large scale and I’m learning the differences as I go.
This model will be used outdoors and I live in the York Pa. area hope that helps.
If the pics load you’ll see I’ve started my station using 3/4" blue foam with door and windows marked in.
The back side will abut a below grade siding about 60 scale feet long. The foot print of the structure is 48" x 16" without surrounding platforms.
Now for the help. I plan on covering this with real stone, as I have a good bit of left over from a home project. I want to use thin set tile adhesive as a glue/mortar as I think the color should be about right. Any comments,suggestions,thoughts? All would be helpful.
The roof is to be made with coil stock, as I am trying to get the look of the old HO Rico station roof. For those of you who don’t know this kit the roof rolls out and up at the building line. To do this I will either tape the aluminum to a piece of 3" PVC pipe or cut a slot in the pipe to hold it as I form it over the pipe.Will I need to heat the aluminum for it to hold the roll? The only other way I can think to make this roof would be to plank the roof like a boat hull with wood strips to get the roll and I think this may be a little harder. Comments?
Once formed the roof will be covered with 30 weight felt cut to strips(maybe ice dam as it’s pre-glued)and then I want to try to coat this with granulas. Anything?
Looking forward to your responces as the building is on hold till I’m a little surer of what I’m doing
Dave
