I’m about to put the marker lamps on my new caboose. Im using Ozark’s Marker lamps Kit #1028.
With the kit for 2 lamps came the jewels, 8 of them. 2 Green, and 6 Red. I used the search engine here and couldn’t find an answer. Obviously red to the rear. With only one green, would it be to the side or the front? And/or did I jest get shorted two green Jewels? OR what should the correct colors be in which direction should they be pointing?
