well, Vic, one thing for sure - none of the still permitted chemicals will do the trick.
the survivors of your onslaught will make new nests somewhere nearby.
you won a battle, not the war.
since Folidol ( = good old DDT) gets more and more expensive herabouts, we started to experiment.
best way to kill insects is fire in the hole.
be it hornets, termites or ants, it is always the same:
pour a generous quantity of gas fuel into the hole. don’t be shy, use a quart or even more, if you suspect a large tunnel system.
wait two or three minutes, then (from some paces afar) throw a burning paperball onto the entrance.
not ownly may you admire a nice fireball, but if you look quick enough, you can ubicate the seconary entrances by secondary fireballs.
and don’t be afraid about your plants. what does not get roasted instantly, will not be harmed. the gas will explode, not seep into the earth.
if your neighbours start talking about strange fireballs in their gardens, you know, it was a big nest.
(from personal experience, take my advise, that one should have a close look for secondary entrances at the place, where one plans to stand, when igniting the gas. a “Marylin Monroe” air gust from below comes very unexpected in the field or in the garden)
if done right, we have to redo about one nest out of ten.
in the eternal war aginst the insects, man has to either become a criminal (thanks to greenp**s and similar, or he has to take out a credit to pay specialists, who will use the chemicals he may not buy, or he has to prepare for a very long campain.
