I bought a second hand 38 ton shay that has a phoenix sound board in it. The original owner did some custom wiring to put in that system.
The trouble is the shay runs in the opposite direction as the rest of my engines. The easy fix would be to open the smoke box door and flip the polarity switch back there but that has been disconnected. The on and off switch works the sound system.
How can I get this shay to run in the right direction? Is there wires I can switch on the main board or somewhere else to change the polarity?
Do the pickups at the motor blocks need to be swapped?
Thanks
