I need some input as the what is the recommended height between two tracks that cross over each other. I plan on using deck bridge where they actually cross over each other. The second question is how much running sistance is required to acheive this elevation difference and keep it a a reasonable grade.
My existing plan has a 33 foot run of track from the lower track to the upper where is crosses over the lower and most of it will be ladder track type if support as the area it is located in is the narural drainage for the back yard and I can not fill it is. I have been contimplating building an 8 foot diameter concrete or stone arch bridge alow 3/4 of the 8 foot curve to allow for drainage, but also give a good foundation for the track.
Oh the largest Locomotive I am using is the bachmann 2-8-0 consolidation 1:20.3 scale if this makes any difference.
Dan S.
