Gives you reason to experiment. You can also find out interesting things when you have sons,
like…
1.) A king size waterbed holds enough water to fill a 2000
sq. ft. house 4 inches deep.
2.) If you spray hair spray on dust bunnies and run over them
with roller blades, they can ignite.
3.) A 3-year old Boy's voice is louder than 200 adults in a
crowded restaurant.
4.) If you hook a dog leash over a ceiling fan, the motor is
not strong enough to rotate a 42 pound Boy wearing Batman underwear and a
Superman cape. It is strong enough, however, if tied to a paint can, to
spread paint on all four walls of a 20x20 ft. room.
5.) You should not throw baseballs up when the ceiling fan is
on. When using a ceiling fan as a bat, you have to throw the ball up a few
times before you get a hit. A ceiling fan can hit a baseball a long way.
6.) The glass in windows (even double-pane) doesn't stop a
baseball hit by a ceiling fan.
7.) When you hear the toilet flush and the words "uh oh",
it’s already too late.
8.) Brake fluid mixed with Clorox makes smoke, and lots of
it.
9.) A six-year old Boy can start a fire with a flint rock
even though a 36-year old Man says they can only do it in the movies.
10.) Certain Lego's will pass through the digestive tract of
a 4-year old Boy.
11.) Play dough and microwave should not be used in the same
sentence.
12.) Super glue is forever.
13.) No matter how much Jell-O you put in a swimming pool you
still can’t walk on water.
14.) Pool filters do not like Jell-O.
15.) VCR's do not eject "PB & J" sandwiches even though TV
commercials show they do.
16.) Garbage bags do not make good parachutes.
17.) Marbles in gas tanks make lots of noise when driving.
18.) You probably DO NOT want to know what that odor is.
19.) Always look in the oven before you turn it on; plastic
toys do not like ovens.
20.) The fire department in Austin , has a 5-minute response
time.
21.) The spin cycle on the washing machine does not make
earthworms dizzy.
22.) It will, however, make cats dizzy.
23.) Cats throw up twice their body weight when dizzy.
24.) 80% of Women will pass this on to almost all of their
friends, with or without kids.
25.) 80% of Men who read this will try mixing the Clorox and
brake fluid.
I didn’t try the Clorox thing, so I’m one of the 20%. Have seen bad results with Chlorine in my life. I don’t need knew experiments.
