Fortunately, I have a small “personal budget” that layout projects are funded by. Unfortunately, it’s the same budget I use for work & travel expenses… so Chris, that should fully explain the burritos. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-foot-in-mouth.gif)
And being a frugal boomer, I’d hate to miss the better deal. So that’s why I’m considering an alternate material for sheathing and shingles, colored ABS. Colors and thicknesses are limited, but I think I can get the two colors I need (for “barn red” walls and green shingles). I have samples coming, so we’ll see. The main problem will be, I think, clean laserable engraving & cutting. It will be like the styrene probably: raised edges, less distinct engraving (vs. acrylic). But if it works, the ABS will be a $90 purchase, vs. a $400 purchase for acrylic.
I may do a mix. Green acrylic for the roof, due to potentially better UV resilience; and barn red ABS. Still evaluating. I almost went with a wonderful HDPE, correct thickness and great color selection, and dirt cheap. Even a slight texture. But PE is practically non-bondable; and the only true adhesive I found (Scigrip PPX5) costs $190 a can!! So heck with that.
In the mean time, I’m working on the core. It took quite a while prepping and fitting the bits for the main module, due to how many parts are involved. But I was pleased that, with few exceptions (where I screwed up with laser focal length), everything indeed fit together. It was fun!
Next step is to glue all the parts for each segment together (4 modules, body and roof, 8 separable assemblies). I was going to haul everything out to the layout for a check fit, but will forego that until the adhering is done. I don’t trust the blue tape, and it would suck if a module exploded en route. At this point, if anything doesn’t fit, it will be the concrete that changes.
===>Cliffy
