David, yep, that’s more along the lines of this project’s scope; but perhaps at a later time. Thanks for your thoughts in all my lengthy and sometimes tiresome build logs, I appreciate them very much!
Hey John, those are all great ideas for mill interiors. However, this isn’t a mill. Also, there will be no interior. I’d like to do the interior on the next mine, and that would center on the main hoist / shaft area, which includes the enormous pump engine. If this were an indoor layout, I’d love to detail the other main sections of the building: the cable tarring room over the ore bins, carpenter shop, etc. But for this model, no interiors; it’s just not designed for that. But thanks Brutha, we’re on the same wavelength.
The first objective today was get the power supply figured out. Until I lay a 12v utility bus on the layout (hopefully next spring), I’ll power this thing from rail power (DCC). It only draws .5A, my track PS does 10A, and the 2 locos I can run simultaneously draw around 3A each. So there’s plenty of extra for this. Here’s the connection area:
At the left is the main barrier strip that accepts the wires from the rails (21V DCC). Just to its right is the full-wave bridge rectifier, and to the right of that is the DC-DC voltage regulator. These are pretty cool, you can dial in the output voltage needed. About $5. The output from this is set to 12v DC to the LED’s (but I’ll probably back it off to around 8 or 10v, it doesn’t need to be this bright). On the wall exterior below the barrier strip is a round waterproof rocker switch to turn the whole thing on/off.
I was pretty happy to scrounge all the needed bits from (failed) prior projects!
Next came the window diffusers. I experimented a lot with various sprays on plastic sheet, here’s an example.
In addition to “picking up” the light and making the window illuminate better, you can see why I need to hide all the interior wiring & etc.
Nothing was really working, because the only translucent material that looked good was also not adhering well to the plastic sheet I sprayed. It was asking to flake off. Rrrr. I wasn’t interested in making this a sub-sub-sub-category science project. Fortunately, I noticed some stuff seeming to have the right opacity: a roll of poly drop cloth! And sure enough, pieces of this gave enough opacity to hide the interior, and plenty of light transmission. I measured and, using double-sided Scotch tape, adhered pieces all around. I used a popsicle stick to burnish the tape joints.
I may wrap more poly sheet strips over some of the up-light bars, because testing showed that this really helped in the few cases when they were visible through a window.
After that diffuser effort, I put the whole thing together – roofs, cupolas, everything – and here’s some shots of that.
For this build, I’m calling it a day on the lighting, and what one sees through the windows. That’s good enough for me. At some later time I’d like to detail the “interior” with photos, silhouettes, that kind of thing.
My next focus will be on the ore bin, with its chutes. Lots for me to 3D & 2D print there, even though I’m having Shapeways make the detail bits. This will take a long time, since there are 10 of these chutes to drill / fit / assemble / install. I have no idea how it will go, but hopefully not too roughly.
After that, roofs… oh boy…
Thanks for hanging with me guys,
===>Cliffy
