I don’t know where else to ask this so I will ask it here because I do want a review. For the bench work section of the layout which will be the yard and maybe also the wye area I want a flat hard surface that is weather resistant/proof. I was thinking of making this bench top out of trex decking or some other composite decking. But it is a very expensive product and I don’t want the rounded edges, I would want them flush fit. That means ripping each one. When looking at siding I see that Hardie makes a smooth fiber cement panel and also a stucco fiber cement panel. 4’X8’ sheet materiel. Its about the same price if not cheaper than exterior grade plywood. It is thinner and would need more bracing. But best of all is made to be weather resistant and rot resistant.
Has anyone used it for this or even making buildings for the layout.
