d this previously on GRW forum and changed a few thing at Greg E suggestions and though I would repost it here:
Looks good Bill.
They are still used to this day. Unfortunately, they aren’t very effective. Modern trains are too big and heavy. If a single car is derailed, they have a chance, but multiple derailed cars will shred everything.
Shane
They are not rerailers, the inner rails and/or heavy timbers on the tie ends were designed to keep the derailed equipment on the bridge/trestle. Upright cars are easier to rerail than junkers pitched over the side.
They should be inboard enough that the whole wheel can land on the ties, journal boxes included if the rails are tall.
Yes, they don’t rerail the car. There is no lifting mechanism to lift the other wheel up and over its rail to put its flange back on the inside of the rail . The spacing of the guard rail is such that it will place the other wheel on the axle near its running rail, like John said, to try and keep the car upright. Guard rails are usually made from a lighter rail the the running rails, rail that is no longer usable for running rails. Over the years of running and rebuilding the trolley line near my house, the lighter rails became guard rails. During the last major rebuild, one of those rails was donated to the Arden Trolley Museum. It is stamped with the original railroad’s initials (P&CSRR) and the date it was made (1871).
guardrails for optical reasons (bridges etc.) i just place against the raised molding of tie plates (on LGB track) (see mock-up in upper left corner), leaving a somewhat bigger gap.
where i put guardrails against actual derailment hazards, i cut out the railfoot of the guardrail, to place it nearer the main-rail.
depending on visibility of the affected spot, i either nail the guardrails down, or fasten them with glue. easy does it (said the lazy)
That’s correct John. If you burn off an axle, they might get you over the bridge, but anything more serious and you’re in big trouble. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-surprised.gif)
Battle River Trestle out of Edmonton in 2012. Track speed on bridge is 40MPH… 17 cars went over the edge. Thankfully it happened 30 behind the locomotives.
The bolted rail in the center of the photo is one of the guard rails. (photo from CN foreman)
Well that was what the designers said… forces have changed … maybe they need Aristo flanges!
