Thanks Stan and Bob,
Rooster, RS-36 is in the design phase
reprinted the doors at the 3 different resoloutions
Blue is fast, green is normal and white is high settings for the Rep2
reprinted the fans after deviding the sections, blue is the orignal
Frame floor and supports
test printing of the bogies
Looks like tomorrow I should have all the frame pieces and should be able to start assebling parts
underframe on the right, base/floor on the left
for the sides/body only thing left to print are the doors at a higher res
bogies are starting to take shape also
How long did it take to print the doors in each of the 3 resolutions you show?
Were there other library members threatening you with guns and knives to quit hogging the machines, or are they relatively unused?
fast and normal doors took 15 min each (wide and small door is 1 print)
best setting was 25 minutes for the 2 pieces
At this time the library loves me because iām kinda the resident expert already and helping other people
I used 1 regualr printer today 11-3, the 2x which prints abs plastic (the pink stuff currently) hardly anyone uses, the 2x and abs is harder to use. Some days there is nobody else therer for a few hours and I ccan shoot more pieces than I can keep track of
Worked on the bogies today
all the big pieces for the main body and frame are done for the gp30c, doors and a spacer for the walkway still need to be printed
also printed some black freight sideframes
Wow that is cool. Wish our library would get one of these things
Painted this red so I can heat test the engine outside this summer
excellent!
Yeah it was all fun and games untill the chickens arrived
If you are careful Iāll be asking you to print some driving truck side-frames for my GN Y-1 locomotive projectā¦
I have the drawings in 1/29 scale already doneā¦
tac
Lake Fleep SAR Team Leader
I didnāt see that
David Russell said:
I didnāt see that
Rooster cant see depth in black n white or something??
Here, does this help⦠(http://www.gngoat.org/Gn5017.jpg)
Been outside in the weather for a little over a month, the highest temp so far was in the mid 90ās, so far, so good
I posted this on another forum but it seams appropriate for this discussion as well. The issue was availability (or lack thereof) of spare parts, namely Aristo spare parts:
One potential remedy in the near future, maybe now actually, would to use 3D printers and a 3D scanner to scan individual parts off a complete model, then print out replacement parts on the printer. This wouldnāt work so much for motor blocks (yet) but it would for body and chassis parts.
The legal issues could get sticky only you started offering parts for resale outside of an active company but if the company has gone bust, what are the legal thorns then? Anyone going to try to sue if you started printing stuff based on Great Trains cars or engines?
Vic, the legality question I have asked before. Apparently if the part is ācopiedā off a prototype (1:1 thing) then its ok. But if the part is copied off a model, and is specifically made for that make of model, then maybe there are issues, especially if the parts are being sold. As for ownership of any copyrights, or whatever, someone does own the Aristo molds, and Scott Polk is trying to negotiate the rights to use them to bring back the line. But if whoever owns the rights doesnāt stand up and say you canāt do that, then I guess you can do that.
Im pretty sure if your making something for your own use or repair then theres no copyright issue but when you sell them that is where you get into trouble.
Iām not so sure about that Vic.
Repair might be OK.
After all, you canāt ālegallyā copy someoneās photo and hang it in your living room.
However, if itās for personal use, whoās going to know?
Iām sure weāll see lawsuits in the future that will establish the boundaries
