Gondola Loads to conceal sound card and speaker?
I am planning on adding sound to my Sons’ LGB SV Switcher via a trail car…in a Bman Big Hauler Gondola…Will install speaker facing down inside gon, and prob build some sort of enclosure for the rear of the speaker…sound will exit via holes drilled in bottom of gon…
With that said…what type of false load should I install to camo the speaker and sound card? Eli will be 4 in July, so nothing too intricate!
thx
cale
cale nelson said:
I am planning on adding sound to my Sons' LGB SV Switcher via a trail car....in a Bman Big Hauler Gondola.....Will install speaker facing down inside gon, and prob build some sort of enclosure for the rear of the speaker...sound will exit via holes drilled in bottom of gon....
thx
cale
I made a load for one gon by creating a 'box" that fit into the gon, I then added various bit of junk to represent scrap steel on top. When set into the gon it looked like a loaded car, but had a big empty space inside. Shouldnt be hard to create an open bottom ‘load’ like this which would allow the sound equipement to be placed, and then set the load box over it.
