D&RGW gondola and idler flat frames in 1:24. I’m working on 4 frames which will be 1 gondola, 1 pipe gondola and 2 idler flats. The first photo is of frames starting with the end sills, centersills, and sidesills. Frame components are 1/4 by 3/8" basswood. All pieces are notched with a router for easier assembly. I also notched out the coupler location.
End view of gondola frame. This will be a 1500 series high side car. Overall frame dimensions are 16" by 4".
End view of the idler flat frame. I’m modeling the D&RGW 6700 series cars cut down from box and stock cars. Overall dimensions are 15" by 4".
Next 2 photos are the frames with the decking applied. Decking is 1/16 by 1/4" basswood. First photo also includes needlebeam pieces which are 1/8 by 3/8" basswood. These pieces are notched as well. I use Tightbond wood glue for all assembly work.
I gang cut all materials divided up into whatever projects I’m working on and also cut notches and drill holes in the same manner. What I didn’t do with these was drill holes for grab irons and such which I will correct that oversight on my next group of cars. I did drill holes in the endsills for the trussrods. More later. Have a good one. Bill
