Gilbert at GLX has been providing replacement parts for our orphaned Aristocraft equipment.
I have just received a parts order from him, and I feel that anyone who has Aristocraft equipment should know about his parts and service. Last weekend I had the spring holder fail on one of my Aristo streamliner passenger cars.
So one of the parts I ordered was a set of these holders.
After taking out the 4 screws, the side frame just comes off the truck.
And here we see the broken Aristo spring holder with the GLX replacement
And here is the GLX spring holder in place on the truck side-frame.
And here is the truck reassembled and ready to go back into service.
I could paint the black plastic to match the truck, but I don’t think it will be that obvious from a distance.
Gilbert is also willing to make some parts, if he doesn’t already have them in his selection. Last fall I got in touch with him about making some bearing end caps, since I lost one when a boxcar of mine did the old concrete dive from a storage shelf.
So I sent Gilbert the truck, and he made a set of bearing end caps for me. They are now in his catalog of parts.
It fit perfectly.
And now that truck is ready to go back into service too.
I also ordered some Bettendorf side-frames, because in changing out the plastic wheels for metal ones I have broken a few.
Yea, I know, but I didn’t always take the trucks apart, sometimes I just tried to spread the side-frames to change out the wheels. Most times it worked, but, I did break a few. But for some reason I was unable to find the parts from the trucks I broke, so these frames will not get used today. But I am sure that eventually I will use them. These frames do not have the plastic journal bearing inserts in them. The holes are sized properly for the wheel axles. So, if one wanted to add the bearing inserts, they would have to be drilled out.
The other items in my order are the brake shoe assemblies for the Bettendorf truck, and the boxcar stirrup steps. I know that one of my nearly 100 boxcars has a broken step, but I do not remember what one. When it turns up, I will replace the broken step with a GLX part.
I really want to thank Gilbert for providing this service and these parts for our hobby. He is, at heart, an HO guy, from what I understand. But he saw a need for Aristo replacement parts and he has filled that need. Thanks Gilbert.
This has been an unpaid advertisement from a satisfied customer.
 to fix some switches not just Aristo either!
