Any updates on glues after long term use? E-6000, JB Weld, MEK, Epoxy, Silicone, Others?
I built several Piko and Pola building last winter (2014-15) and set them out in April, took them in in Octoger, then when I went to set them out last weekend, I noticed that they were starting to fall apart. I used Testors solvent glue that advertised it contained MEK. I guess it didn’t contain as much MEK as in the past.
My plan now is to use a bullet proof glue so this doesn’t happen again, and back the joints up with wood reinforcing. What glue have you had good results with over the long term and would use again?
