I have today just finished an installation using the new RCS PnP-3AC with Phoenix P5 + P5T sound. This loco started out as an AC RS3 and is now a longer wheelbase NSW 40 class Alco diesel that is being kitbashed by a customer.
After a couple of less than satisfactory antenna placements I mounted the RCS RX-8 metal cased receiver on the back of the cab wall. I drilled a small hole through to the cab and mounted the AZARR 27 Lite antenna vertically up one corner and around the top of the roof.
I have just range tested the loco and I could reliably control the loco and blow the horn with out it dropping in and out, up to at least 300’. I couldn’t get any further away because I came up against an electrified fence for keeping horses away from the garden.
To say the least, I was astounded. The only other locos I have tested to get anywhere near that range were an USA F3 and an AC E8. Both of which allow an antenna to be stretched out up really high.
The really interesting part is I had no extra motor “noise” suppression components on the AC motor blocks. Just the suppression fitted by the factory.
I have a friend with an SD-45 that has reasonable range and shortly I will try the install method on it.
I will report back on what happens.
