Pete Thornton said:
Mike Lafferty said:
Thanks Pete
Do you have a part number? - and even better, a schematic?
Mike
Mike,
I bought a bag of them 20 years ago - still have some a lot left. The bag says All Electronics, part RXE-065, which is still on their website:
http://www.allelectronics.com/make-a-store/item/rxe-065/resettable-circuit-protector-0.65-1.3-amp/1.html
Not sure what kind of schematic you are looking for. They are essentially 1 amp fuses, and you can set up multiples in parallel for higher current values - e.g. use 10 for a 10 amp loco. (Yes, I know they trip at 1.3 amps, but for our purposes it doesn’t matter as long as they trip before the wiring melts!)
Chapter and verse is in this doc:
http://www.littelfuse.com/~/media/electronics_technical/application_notes/resettable_ptcs/littelfuse_polyfuse_ptc_selection_guide_application_note.pdf
Thanks for the info Pete.
Sorry I got confused when you mentioned putting them in parallel. Tha’ts why I asked for a schematic. I stoooopidly thought you installed the fuses across the pos/neg instead of using multiple fuses in parallel(to increase rating) in line with the positive line from the battery.
This type seems the way to go for sure!
Thanks
Mike
