I’ve wound up with five Bachmann coaches (well, three coaches, two obs. and a combine) and I hardly ever run them because our layout has evolved towards the abominable 1:29. Nobody makes a standard gage wooden coach of reasonable size. Into the 1920s roughly half the coaches in use on standard gage lines were still made of wood. By the end of new production, around 1910, they were 70 feet long. I was thinking of trying to downsize some bachmann coaches. I’m assuming they would need to be lowered, narrowed, and lengthened. Like this:
If only it was that easy. I was thinking–cut the sides down at the small upper window, and you’d be well on the way. In this image I cut out the upper window and added three windows worth of length. But it does not look like it’d be very easy. I’m pretty much a "super glue"modeler–p;our on the CA and hope it sticks. Any thoughts?
