Very cool. Now, can you explain the advantages to each mixture for the application?
I know that Antracite burns cleaner, with less smoke, but beyond that I’m clueless.
Maybe this will help with the understanding:
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://apps.dtic.mil/sti/tr/pdf/ADA202082.pdf&ved=2ahUKEwimvMqUiPCGAxUjmIkEHSAeAY84ChAWegQIFBAB&usg=AOvVaw2abuRuhQ9bdnWdctXFWv1j
The above is a PDF download.
And I’ll question next time I go to the museum to see if I can get more info
A thought I feel would have played a part in the mix was cost and efficiency. On the Yard mix you have a small coal box with a heavy workload so they get a burn that will last at a lower cost. On the 100% Bituminous and 100% Anthracite you have a road tender and auto feed, so depending on where you are located one is a local product and the other is an import. JMHO YMMV
