Flash Modifications
My flash pictures are often washed out. I’ve found using some clear plastic(not real crystal clear stuff) in one or two layers will cut it down to about right. Might give it a try.
I’ve been very unhappy with the built-in flash results with my Rebel Xti. For one thing, the combo lens I have is quite long, even when at wide angle, so there is usually a shadow in the flash. Lots of cameras have adjustments for the flash power, but I’ve never fooled with that.
As soon as I can afford it, I’m going to get an external flash that can be triggered with IR. My nephew has one one he can get some really nice results when the flash source is removed from the camera. It also allows angling the flash for bounce off white ceilings, etc.
In the mean time I’ve been using available light and/or lamps and a tripod indoors. Just need to remember to adjust the white balance. I still like my outdoor results better.
Guys, check the manual, you can turn off the flash! I do with my Rebel regularly to get a more uniformly lite picture.
Paul
Jerry:
Good tip! I’ll try it.
Our Pentax Optio Z10 has 6 flash settings: Auto Flash, Flash Off, Flash On, Auto+Red Eye, Flash On+Red Eye, and Soft Flash. We have experimented enough that we are usually able to find a satisfactory flash setting, but the option of a separate flash would still be nice.
Happy RRing,
Jerry
That’s called a “diffuser.” It can do wonders for your photography.
Yes, the onboard flash pretty much sucks on all cameras. If you can use an external flash or better yet, natural light, you’ll get better shots. If you need to use the built in flash try bouncing it with a reflector or using a diffuser like Tom mentioned. Bouncing a flash is easy with a piece of paper. You can also use something opaque as a diffuser. Something like a white Pringles lid. Some guys even use ping pong balls with a slot cut on one side so they can slide it over their pop up flashes.
Play around with your shots. Heck, you guys are using digital. Shoot away! You can delete the the shots you don’t like…
Jon.
