This isn’t a new idea - I think TOC was probably first to post that the spring wiper system on the Bachmann 45 Ton diesel trucks was a weak link. Following his idea, but forging ahead with my own method I’ve now converted 4 trucks to fully hard-wired configuration. Many folks here would only need to extend the motor wires, but I do all 4 since I’m still track power. My method wires directly to the motor eliminating another spring contact point, then up through holes drilled in the wiper pads into the loco body. For power I remove the motor traces on the inside of the truck then drill a small hole to secure a wire soldered from the outside to the pick-up pad. Here’s a photo of a recently completed pair coupled with paint stir stick for road trials. I also found and cured a problem with the wobbly wheels rubbing on the side frames for a part of each rotation that gave a less than smooth operation. Hard wired, lubed and with the side frame problem cured with a quick shot with the Dremel - these things run like a dream. Slow speed crawl is awesome
Here’s the test rig…
JR
