Fixing a LGB transformer?
I use a LGB 5003/110 transformer to run my main yard and to power a LGB switch box for 4 electric switches.
I have pins on the wires that fit into the electrical connectors on the back so I can quickly plug and unplug this transformer for when I’m not running trains. Yesterday I went to put the plugs in the spring loaded terminals on the back and 2 had lost their spring?
How does this thing come apart? It looks like there are 2 little nubs on each side which I tried prying underneath but I felt I was doing damage to the casing. I did remove the throttle dial and it is still not letting me in. I don’t see any screws holding it together.
I may be wrong, but I thought the cases on these were riveted together, you might have to drill them out.
Someone here will know for sure.
Oh no I hope it is not riveted together. I wonder if I can pop out the terminals without taking the transformer apart? I also wonder what happened to the springs in there. I don’t think they burnt up because the transformer still works if I hold the wires in the terminals.
It is odd that they both gave out together.
The 4 plugs are like the automotive ones and do not come out easily.
I drill them out and then I use a large short screw to put them back together.
You will find there is a piece of plastic inside that broke for the spring to work and I would suggest you add a cable and 4 pin connector to this power pack for the future and it will be even easier to plug it in.
A great 4 pin connector is available at Walmart for trailer hook ups and is keyed to plug in only one way plus the wires are a good size (read strong).
Thanks Dan. I did just what you said to do and now my little transformer is working again.
Image result for no pic didn't happen smiley
You will have to use your imagination on this one Sean. Imagine a LGB transformer with a hole drilled in the back and 4 wires going in and the ends being soldered to the terminals in there. The 4 wires about 7" long now wrapped in black tape lead to a 4 pin trailer harness that connects to the other end of the trailer harness and to the wiring in my main train yard.
Thanks again Dan.
