Exterior Glue
Yeh… that is a great glue… one of the polyurethane adhesives… requires water to work… dampen one surface… an clamp…the moisture causes it to expand into the pores… built a bridge last year… has been outside since… no deterioration… screwed up an built another from another type… started falling apart within a week…
another thing i like to do… instead of using brads… drill the frame … and use either brass or steel rods cut to length… and threaded with 2/56 die… and through bolt…looks good…and does not split soft woods… am looking for square 2/56 nuts… that would look even better…
the glue really holds… an the bolts provide a mechanical fastening…
