Ron Teten is having troubles with his code 250 Aluminum track expanding so much. Well, we think that is the problem, in this 100 degree summer we had. Looked at ordering one, but no code 250 ones. I saw some code332 ones at Kidman’s display at Marty’s, and after talking to Ron Senek(who’s made a lot of them) I decided I could make one. Used some code 250 brass SVRR rail I had and some AML/Ams narrow gauge ties that Ron had. Used my bench grinder to take off half on each side. Seemed a little floppy up and down so I put some cedar pieces in the ties under the splice and at the ends to hold it flat and level.
What about this… Alternate grinding on the rails. Lemme see if I can make sense of this, after all, I’ve only had two cups of coffee… In the photo above, the rails in the superior section of track are ground on the inside rail, and the rails in the inferior section of track are ground on the outside. If we were to switch the right hand track around, so that the superior rail was ground on the outside, and the inferior rail on the right was ground on the inside, wouldn’t that work better to maintain gauge?
