Ever since I re-introduced a practical glitch free R/C ESC for low cost AM R/C a couple of years ago now, I have made the system available with the Boomerang automatic control option. Whilst the automatic system works extremely well it was not that easy to switch between battery R/C operation and Automatic operation. To do so meant accessing the ESC to change the program. I am pleased to announce that I have developed a very simple plug in push button cable assembly that can be mounted externally. To change from Battery R/C to Automatic battery operation, simply press and hold the pushbutton whilst the loco is switched ON-OFF. Let the pushbutton go and you are ready to switch the loco ON and run using your method of choice.
This new part, # PROG-CHG is available separately and can be used with all of the EVO ESC’s except the EVO-B2. The EVO-B2 can be used automatically but to change the program you will need to access the pcb. Full details and price are at the EVO website. http://www.evo-rc.net/home.php?page_id=3010070711
