More freelance Euro silliness. Will track down to R3 curves with a lot of overhang, due trailing truck geometry. Able to haul rolling stock due a swing mounted loop coupler on the rear. This compensates for the amount of overhang in curves without derailing. It runs very well. Aristo ball-bearing pickups on trailing truck. Trailing truck is pivotted at the rear of the drive block and is load bearing due an adjustable spring loaded bolt head attached to the truck, that rubs on the bottom of the boxcar body. This helps keep the truck on the rails.
Lookin’ good, Tim.
Tim your having too much fun, stop it!
you’re
As in “you are”.
Stinkin’ grammer police
Nice bash Tim !
Technically, when using an abbreviated word/words, the abbreviation should only appear in direct quoted speech, identified by inverted commas, such as
“You’re having way too much fun.” Omitting the inverted commas is incorrect usage, as, when not quoting direct conversation, one would state ‘you are’.
O plez…yor stell hafen tu moch fon!
Vic,
way too much fun. Last item may be a little crane mounted atop a loco or maybe affixed to it. I just need the courage to commence, considering there are so many unfinished projects on my plate.
