I needed to paint the seat frames. I haven’t really figured out the color(s) they were when installed in 1894 so I made something up… My idea is that they were two tone, the interior photo suggested this to me. And, it will highlight the fancy knot pattern. So how to accomplish this on a bazillion little seat frames? My idea was to make a little brass mask that keyed into holes in the knot pattern.
insert the mask and give it a spray, repeat… then make a wooden frame for the seat itself to rest on. if I made the seat solid and one peice i would have had a difficult time mounting the seat frame solidly to the floor. I probably should screw or otherwise pin them down so they stay put I suppose epoxy would work for a while but not for ever especially if this car takes a tumble (nah, that would never happen!) So this open frame leaves access to the holes in the little feet of the frame.
oh, how did i get all those big brass nails into the end of that little bit of wood frame? I set up a holder in the tail stock of my lathe, put a bitty drill into the chuck and went at it…remember I have 48 seat for the two cars and there are two frame peices per seat, I needed a bunch of them. this worked out pretty good.
Ok, how do they look? will this work out? I had a seat leftover from earlier coaches and set them up in place inside coach #2
