Just gave this SD 40-2 a face lift, and wanted to post my results for future modelers looking for help doing some paint work of their own. hope this helps. i dont know how many fans there are of Conrail here but I grew up around the blue and have aquired this USA model used just recently and decided to go ahead with the transformation even though it didnt really need it. Im very please with the results and happy to add some blue to my line. i used acrylic through an airbrush for my color, and shot it over flat white Krylon which i used as my base, then clear coated with gloss clear duplicolor in the can. I contacted Stan Cedarleaf for the decals. I used wet transfer decals for ease of application over the not so smooth surfaces, then finally covered the decals with a matte clear acrylic through the airbrush again… about 5 coats. the hazyness you see is the difference in the color tone due to applying the matte clear over the gloss. the matt really lightens up the color in those areas. ill do a weathering job on this engine after a few months of service so the differences in sheen is unimportant to me. before…
after…
inbetween…
The garage is out back behind the house. That would be about a 50’ run for the dryer vent. I don’t think there would be much heat left.
