I have an LGB 26194 Mogul with a Zimo 696V decoder. The Automatic Brake Control is not working fully on it. When the engine enters the block, it slows down but does not stop. It creeps along at a low speed step, with the brake squeal sounding, until it gets to the end of the block, where it resumes full speed. If I change CV 141 the distance where it comes to an almost complete stop changes, as it should, but the engine still will continue to travel.
None of my other engines have this problem.
I am pretty sure I have it wired correctly. I took the engine apart, to fix a separate problem, and rechecked the wiring. It looked ok to me.
Any suggestions?
