In the very early 1900s the EP&SW ran through our part of the country, and the history is pretty well documented, but the depots, not so much. A fellow G Scaler conversed with me about a model of the depot at Hereford AZ. These are the only pics I have found to date. In the second picture here, note the walk out on the second floor on the right side of the picture. This does not look as if it is present in the first picture. Also, it seems there was a bay window trackside.
This appears to be an SP ‘Type 22’ Depot. It is 20 scale feet high, 25 scale feet wide, passenger section is 32 scale feet long, and overall it is 72 scale feet, which was typical for the Type 22 depots, since the freight portion would change based on the needs of the community. I got a pretty good start on it the weekend. LOTS of windows and doors in these old buildings! I need to procure 4 walk-through doors still, as the ones I have are not correct for the times, and will cut openings when they are in hand. The stairs wil be quite a challenge as well. Election time needs to get here quick, I am almost out of political signs!!!
