El Cheepo conversion of Scientific Toys cars
El Cheepo conversion of Scientific Toys cars from Single axle to double axle bogie Start with your typical very inexpensive type car:
Remove the bogie, cut off the side frame:
If you have New Bright trucks, its a straight conversion, no mods needed
If you have other trucks a shim will be necessary, this is two .40 styrene pieces:
make sure the shim is wide enought to allow the level bumps on the chassis to rest on the shim otherwise the car will wobble. FInal product, I used a brass retainer with the screw to hold the truck. I have link and pins so thats what shown. If you have couplers on your trucks they go right along with the truck OK.
One more Quickie, I have another boxcar, but wanted something a little different
(http://1stclass.mylargescale.com/vsmith/ElCheepoBoxConverison01.JPG)
So I went from this, large way too big for narow gauge:
(http://1stclass.mylargescale.com/vsmith/ElCheepoBoxConverison02.JPG)
To this, some small diameter wheels I picked up down the line:
(http://1stclass.mylargescale.com/vsmith/ElCheepoBoxConverison03.JPG)
Overall looks much more like a narrow gauge boxcar.
(http://1stclass.mylargescale.com/vsmith/ElCheepoBoxConverison04.JPG)
Stock wheels dont fit Scientific trucks, they are too wide so thats why I usually replace them with trucks, but these wheels allow for a nice different look.
