Dan Pierce said:
20ma lights give off a lot of light. You can reduce it to 12 ma esp for battery operations and with 2 in series save battery power/like.
However for dual leds, series operation is not easy for most but 12 ma instead of 20ma is a good way to go.
I would have front and rear as dual white/red leds and dual red/green on the sides. For the eggliner with 6 lights lit and 12ma per light, current would be minimal for battery operations
For DCC I would go with the full 20ma.
Dan I agree. i posted as 20 ma as most people understand that value for LED’s, I was going to use between 10-15 ma current limiting with DCC. Reason is I want to use Rule 17 for the headlights so I need to pick a nominal value at full brightness that will give the dimming I want at stop. CV’s will be adjusted for the dimming and brightness.
it will be wired as 4 circuits, Front Light, Rear Light, Marker Lamps x2= 48 ma total. Each side the marker lamps, RED and Green, with be wire in series.
Before anyone comments, normally a RED LED voltage (~2.2 Volts) and the GREEN LED (~3.2 Volts) can still be wired in series and current limiting works best to prevent destroying the LED’s.
I am using 5 mm Cool White LED’s for the marker lamps and painting them with kids fingernail polish you find at Michael’s.
