Hi all!
I’ve been working on creating a 3D drawing for an EBT vulcan truck, which is intended for 3D printing. I have finished my first versions, and have printed test copies. At first I only intended them for my own models, but have decided to make them available on Shapeways, so that other modelers might be able to use them. I have a leaf spring version that I created for under my Iron Horse Engraving caboose, and a coil spring version intended for use under freight cars. I did a conversion of a Bachmann flat to depict the EBT’s second generation boxcars, and put these trucks under it, and it really does give the model a much more EBT look! They are reasonably accurate for the trucks used under the hoppers, flats, boxcars and cabooses on the East Broad Top Railroad. They are designed to accept the large metal Bachmann wheel sets, with the 3mm axles, which work out reasonably enough for the dimensions of the EBT’s 24 inch wheels. To connect the side frames, a short piece of brass can be used. Printed in plastic, these trucks are a cheaper alternative to the more expensive brass, or inaccurate plastic Bachmann vulcans available. They should hold up as well, as I left enough space above and below the axle pocket to include a simple brass bushing. I’ve used them on my test track, running for hours, without any noticeable wear…even without installing bushings! If intended to be left outdoors for long periods of time, I would put a coat of UV resistant spray paint on them after construction.
Here are the links:
