Jon Radder said:LMAO.........sorry it was the beer gods talking....I couldn't think of jeans names at the time and Gloria Vanderbuilt or whatever she is came to mind....Gloria Peterbuilt is a MAN JEAN and I would wear them... Gloria Kenworth Gloria Volvo Gloria White Gloria Mack (not bad) I was keeping Ken in mind also with the tractor theme. I'm always in trouble and more than deserving for retaliation!!! Are you going to spank me? :)David Russell said:He's not in trouble, but you might be for that Gloria Peterbuilt remark :D
[i][/i] Ken, I'm sorry I got you in trouble with Jon..
Mother does that and all it does is put a smile on your face
edit It’s only page 2 what happened to the pole in the caboose pocket thread that was here
David Marconi said:
Mother does that and all it does is put a smile on your face edit It’s only page 2 what happened to the pole in the caboose pocket thread that was here
As usual, David went off on a tangent about somethin or other…
The forum topic was EBT Tenders…could this be in any way something like “Chicken Tenders”…I have seen that on a bar menue in Syracuse, or somewhere… “Easy Bake Turkey Tenders”, maybe…?
With Thanks Giving Turkey in mind, I couldn't stop myself.....!!!
Sorry…
Bumping to make page 3
Bump
Bump
5 straight shots of my mug…
Total abuse!!
David Russell said:Thats OK. I'm saving it for my jail. You won't be the Sheriff :D
5 straight shots of my mug.... Total abuse!!
It’s been almost a week and still waitin’ on the jail Ralph?
I’m excited prisoner or not!
Ah Haahhh…Page 3
David Russell said:That's a Winter project. For now you're wandering aimlessly in digital storage :) Ralph
It's been almost a week and still waitin' on the jail Ralph? I'm excited prisoner or not! ;)
I’m not sure when “poling” was outlawed, but the EBT put the pockets on cars it built up through the 30s. All the mikes still have the poles hanging from the tenders. The EBT always sometimes felt itself somewhat immune from the federal rules it didn’t agree with, so even if the process was officially outlawed, it wouldn’t surprise me that they’d keep doing what worked for them.
The chains–as mentioned–would be used to pull cars if a coupler broke or some such emergency. I’ve also seen chains draped over the rails next to locomotive drivers to serve as something of a wheel chock if the loco’s being serviced. Usually this would be done if engine brakes were going to be compromised by the servicing, or there was otherwise a chance of the loco drifting. In this case, the chain would probably just be pulled off of one or two hooks and draped under the tender truck–easier than removing the entire chain.
Kevin Strong said:
I'm not sure when "poling" was outlawed, but the EBT put the pockets on cars it built up through the 30s. All the mikes still have the poles hanging from the tenders. The EBT always sometimes felt itself somewhat immune from the federal rules it didn't agree with, so even if the process was officially outlawed, it wouldn't surprise me that they'd keep doing what worked for them.The chains–as mentioned–would be used to pull cars if a coupler broke or some such emergency. I’ve also seen chains draped over the rails next to locomotive drivers to serve as something of a wheel chock if the loco’s being serviced. Usually this would be done if engine brakes were going to be compromised by the servicing, or there was otherwise a chance of the loco drifting. In this case, the chain would probably just be pulled off of one or two hooks and draped under the tender truck–easier than removing the entire chain.
While I don’t know if the EBT ever did this, but I’ve seen chains used in a move like poling, where the car to be moved needed to be pulled, rather than pushed. I suppose when you have pockets all set up on both ends, you could use the pole for a move in either direction unless the move put the car in a down-grade situation
What is interesting, I noticed while modifying my Aristo snow plow it has poling pockets molded on it. This has been an educational thread for me as many in the past and still more in the future.
Thanks guys and I hope I’m not still in trouble with you Jon!
Oh, I dunno. Stay tuned on the Cigar Store thread to see what develops inside
…winking…
