The railings & stanchions are fabricated brass. Rather than rolling the end of the angle iron around the hand rail I soldered on a tube to create the illusion. If I move past the study model and make a small run of these cars I’ll make a fixture to aid bending, shaping and rolling the end of the brass angle.
When making parts I often make them the same way they were made in 1:1
If a part was cast I’ll look at making a casting, if it was a stamped part I’ll try to stamp it, if it was blacksmithed I’ll fabricate it.
-The pole pockets are brass castings made from my hand built master
-The stake pockets are a brass stamping.
-The Carmer style uncoupling levers are “blacksmithed” for each car, as the pivot point, hanger and coupler offset varies from car type to car type. This one is the easiest version as it is straight in elevation and plan view.
