It has been a while since I have posted any work. I was at Roger Cutter’s 1:20 RGS East this weekend and took advantage of the great weather to take some pictures: Scratch built EBT steel flat # 108. This is a typical example of the 22 steel flats built in the EBT shops. Plans were drawn by J.T. Derr and are available through The Friends of the EBT.
B end 108
I am doing a load of 60 lengths of 33 ft rail.
Scratch built EBT fishbelly flat # 73. This is the one and only example of a fishbelly design and was the first steel car on the EBT. Built in 1902, it predated the first steel hoppers by 11 years or so. 73 survived into the 50’s, but it’s final disposition is unknown. More information and plans by Lee Rainey are in the Winter 1989 FEBT Timber Transfer.
On both models I used trucks from RY Models, the same ones used on his beautiful brass hoppers. Couplers are the new Accucraft #1 scale working couplers (which are perfect for the 3/4 size EBT couplers). Frames are a combo of brass, styrene… basswood for the decks. Cut levers are fabricated in brass, poling pockets are cast from a brass master and stake pockets are brass stampings. All rivets are individually placed. Both flats need a little more weathering. I have dedicated my Bachmann hoppers to rock service. The highly detailed RY hoppers will run in a separate consist delivering coal.
I am in the process of studying photos and applying weathering. On some of the Bachmann cars I have ground through from the inside to create paper thin areas to simulate rust through. In other areas I have riveted steel plates in place to cover rust outs.
I have also fabricated cut levers and added the Accucraft #1 scale couplers to all the hoppers.
Also in the works, I am doing a heavy working weathering job on my RY EBT #14 mike. I will post some photos when finished. Geoff Ringlé
