Hi all, It was time to get some concrete pipe loads on the RhB. I used some leftover 1/2" PVC pipe conduit. Turned both ends (male & female). Painted with quickdrying, sandable gray primer. Let dry. The overspray with same type but white. Far enough way that it is like overspray and almost dry when it hits the pipe.
Now it will be on to finishing the skids; what a joy that is to cut on the bandsaw. Had to disconnect the dust exhaust, half the stuff kept disappearing up the tube and into the “Big Bag”.
