Here is an update on the details above.
Since I wrote the above comments I have had a chance to study exactly what Bachmann is actually offering the LS community with the K27.
I have decided not to detail how to modify the existing socket pcb in the tender. There will be no need to.
Rather I will offer two ways of installing battery R/C. Neither of which will involve any changes to the existing Bachmann wiring.
Firstly, no matter what brand of battery R/C you will be installing, the Bachmann socket pcb provides an input terminal to access the pcb.
A. If you are installing a PNP controller with a built in, or plug in R/C, such as the QSI + Airwire system, you can use the BATTERY - TRACK switch as an effective battery supply ON - OFF switch. It will be up to you how you actually install the batteries and access them to keep them charged.
B. If you will be installing an non PNP R/C system such as Airwire, Locolinc, RCS or EVO, that TRACK - BATTERY will not really suffice. You will have to still install the batteries plus an overall ON - OFF switch and method of on board charging if you don’t want to continually keep removing the tender shell to charge the batteries.
In this instance I will offer the BIK-U3 installation kit plus a Y-CABLE harness for those want to use twin stick Ni-Cd or NiMH batteries that have Tamiya connectors.
These two items will greatly simplify the installation for either A or B methods no matter which brand of R/C you choose to use.
Assuming you are choosing method B, RCS will detail two ways of going about the battery R/C install.
I won’t get into specialist sound systems but rest assured whichever RCS system you use it will be sound compatible.
1). This will be a very simple method of installing battery R/C.
The dummy plug is left in place and the output of the onboard R/C controller is simply hooked up to the BATTERY terminals and the TRACK - BATTERY switch is set to BATTERY. The track voltage is positively isolated so only the output of the R/C controller is fed into the Bachmann electronics.
Performance is just the same as it would be on track power but with a big improvement when compared to running on dirty track.
Because the lights on the K 27 will come on an instant before the loco starts to move, there is no real reason to go to a higher level of installation unless you want to have all the lights on even when stationary.
2). Now that RCS is confidant that Bachmann have got the basic socket design right, RCS will be offering a totally new Plug’N’Play R/C controller designed especially for the K 27. The PNP-1.
Simply remove the dummy plug and plug in the PNP-1.
Plug in the suitably mounted RCS RX-8 receiver module.
Then hook up the fused battery supply, via BIK-U3 if you choose to, and switch the TRACK - BATTERY switch to BATTERY. (The PNP-1 is designed only for battery power. You cannot use constant track voltage as the power source).
Then switch the BIK-U3 switch to ON.
Link the PNP-1 to the RCS TX-24.
You will be set to go.
The PNP-1 will be capable of a genuine 3 amps continuous and be plug compatible with the Phoenix P5 + P5T sound systems.
It will also have options for use with other brands of sound systems. Because of the way the Phoenix will be wired to the PNP-1, I see no problems using the built in K 27 chuff timer, as it comes from Bachmann.
The RCS PNP-1 controller will have built in motor “noise” suppression so that long range is assured when the system is correctly installed.
Subject to successful testing of PNP-1 prototypes, the PNP-1 will hopefully be available at the end of Feb or early March.
RCS is not in the habit of announcing vapour ware.
Rest assured, it will happen.
BTW. This new PNP controller will also fit most AristoCraft PNP locos.
