This is a shortened Accucraft J&S coach with G.A.L. (http://www.thegalline.com) full baggage sides.
The original car is 36’ 2" so I decided to go for it and shorten the Accucraft car. The kit is the same full baggage that I made a few months ago:
We designed the kit with scribed siding on the sides, but blank on the reverse (not that you can laser cut both sides very easily!) Alan at G.A.L. did a great job of cutting the battens so you can order and make either version. The 4-panel door on the original car is carefully sized so that if you only use 2 panels, you get a 36’ 2" car. In practise, with the big quarter-round door frame, you need a 2-panel door from G.A.L. with lots of space at the side to glue it behind the walls. Cutting the frame was easy - and it is U channel so you can re-glue it with strengthening in the slots. The roof was easy too, though you have to re-cover it with either masking tape or aluminum duct tape.
