Google AI is (sort of) your friend.
" 300 lumens is a moderate, comfortable level of brightness—roughly equivalent to a traditional 25- to 30-watt incandescent bulb or a 3- to 5-watt LED bulb"
How do you plan to make your logo, film transparency or print on thin plain paper? If you use an LED, I think you may be best pointing at the back of the housing. No bright spot in the middle or dim outer edges.
Bill, let’s say (hypothetically) that you design the structure like a can with a removable lid, like this, or this.
If your internal depth was 8-9mm, you could stick some led tape around the internal wall, pointing inward.
Since they run on 12v max and are quite bright, a 9v battery would dim them some, which might work out better for your application.
I have 1:1 experience over illuminating a drumhead. When Al Pomeroy was active with the RR Museum of NE, he and I worked together to create a drumhead for their Christmas trains. I cut the translucent white acrylic and applied translucent red vinyl with cut out lettering. Al had a custom aluminum box fabricated and we used RR window gasket to mount the acrylic. I installed way too many 12V bright white sign LEDs around the perimeter of the box. It looked great lit up, but overpowered the Christmas lights on the cars and station in photos. I suggested they remove 75% of the LEDs. I don’t know if they ever did.
It’s easy to get too bright with LEDs. One or two 5MM warm white or amber would probably be enough and not give off much heat.
Edit to add this shot from RMNE in 2017. I had it backwards, the drumhead was washed out in photos when exposure set for the Christmas lights…
Thanks guys, I may have found an easy solution to the drumhead conundrum on aliexpress, where the drumhead could also be its own on/off button.
I am waiting to hear back. It may be a while…
In the meantime, enjoy some of your & my favourite vintage drumhead photos that I allegedly only stumbled upon while ducking and weaving around the web.
FYI:
Yeah, Taffy and/or Tuffy already cat-a-pulted a report through on this thread to the moderator. To top it off, my cats thought it was a purrrrfectly reasonable thing for them to do.
Peter would you be able to measure the diameter of your drumhead or give me a rough estimate?
You even found a Pennsylvania keystone drum head!
Scott, would you run through your drumhead making process?
Looks to be 35mm overall. The transparent insert, which just fell out, is almost 32mm.
Thanks Peter. I understand drumheads were not common in the UK.
Did you run headboards on any of your trains?
I did up a Sunset Ltd drumhead for my SP streamliners, but I don’t really remember how I did it.
While I continue to wait for my 50cent piece holders (January or February) and my Aliexpress order (Who knows?), I started to contemplate what other fictional garden railway line drumheads might look like.
Any image real or imagined is of course coincidental.
Hey Bill, with your AI skills, can you make an “Ohio River & Western Railway” drum head?
Sure Wayne, I can give it a go… I see it was a real railway early 1900’s.
Need some fact checks… from face book
1 was it called Old, Rotten, and Wobbly Or the Bent, ZigZag, & Crooked Did it have a slogan? Other than Ohio’s Last Narrow Gauge?
2 Aways Narrow gauge? Did it become standard gauge at some point.?
3
No, never standard gauge. I have a lot of LGB narrow gauge, road name Pennsylvania. I found out the mighty Pennsylvania never did have their own narrow-gauge line. At the turn of last century Pennsy took over OR&WRY ownership. They ran it until the 1930’s when the line was closed.
I found a book with all the history:
What you stated was what the locals called it. I’ll have to find the book to see what the slogan may have been.
Wayne, something traditional like this?
The Ohio River & Western had a pretty cool S-shaped Trestle.
Or we could fully “turbocharge” your drumhead…
…Something like this …
…Full CinemaScope, rocket launchers, unusually painted palm trees, exploding volcanoes and a mysterious character who leaves a trail of completed projects, depleted locomotive inventories and increasingly expensive Christmas wish list.
Bill, the first picture is perfect!
“Through the hills”
Nope. Most are US narrow gauge so they don’t use headboards.
Are head boards the signs on the front of the locomotives?
