I was recently drawn over to the Dark Side when the notorious Bruce Chandler enticed me with an RCS system…at a price I couldn’t refuse. As there was no budget for this project, I went on a search for the cheapest batteries I could find. When talking batteries, cheap usually means big. So I found this 14.4V 3800mAh NiMH Battery Pack for the IRobot Vacuum Cleaner. http://www.all-battery.com/144v3800mahnimhbatterypackforirobotvacuumcleaner-roomba4905.aspx For now I mounted the battery pack in the tender. The battery pack can replace the weight in the Annie and I may go that route if testing today proves the tender too heavy. Here it is with the components mounted before wiring everything up. I turned this mess into a nice, neat job but forgot to take a picture.
Not wanting to wait for plugs to be shipped, I used computer plugs to connect the tender and engine. Not having a suitable plug handy for the charging side, I decided to use charging posts. I had on/off switch I could have used, but decided to go with a DPDT switch, which I mounted in the 9v battery compartment. I picked up the switch at Rat Shack, but couldn’t find any suitable connectors there
This engine is an early Christmas Annie I had picked up from Cale. There was no working light in the tender, so I installed one. Still need to paint the light.
As soon as it warms up from the 26 degrees here this morning, I’m going to break out the leaf blower and do some testing. Ralph
Testing went quite well. Ran the Annie about 6 hours. Not continuous, but it was running most of the time. Battery never did run down. RC coverage was good. I had no problems controling the engine from the opposite end of the RR. So now it’s time to put the Annie back together. Ran it today missing a number of parts.
