mike omalley said:
Hmm. As an ignorant but interested novice, it seems to me that Zubi has made his point well--the motor is powerful enough that changing the gear ratio would not increase the number of cars the K27 would pull. As I read it, this is what Stan Ames claimed in the original quote.
There are several videos on Youtube of the K27 pulling cars VERY slowly, for example this one, posted by Stan Ames, who apparently is evil for some reason I can’t quite grasp and may have rigged the thing in some way
http://www.youtube.com/watch?v=Z1eW4phOT4E
But then there are other videos showing the K27 pulling quite nicely at a low speed while also denouncing the thing as badly geared! Huh?
http://www.youtube.com/watch?v=VP9Y7itCtOw
The video above seems to be demonstrating that the K27 can do precisely what the comments claim it can’t do!
I’d love to try one out, and see if I could figure out what the fuss is.
Mike.
As you know, DCC has the ability to custom set the CV values to take care of any performance inadequacies.
What Mr Ames does not explain is which DCC decoder is he using, as in current rating, and what changes did he make to the CV’s to get the K-27 to perform like he says it does.
If Mr Ames finds it necessary to use a DCC decoder that can handle more than three amps, either he is using the higher rating to ovecome the excessive current draw under load, or, the decoder is not rated correctly.
I assume you do understand how a motor car gearbox works?
Our locos do not have the luxury of selectable multiple ratios, so it is important to get a ratio that is the best compromise.
So far, those who have actual field testing experience say the K-27 will use less power and perform more smoothly at low speed by having a 1:29 ratio rather than the existing 1:14.5.
Low speed lugging power will be greatly enhanced. As in double what it is at present.
Current draw will be reduced. Meaning less expensive DCC decoders and on board R/C ESC’s will be required.
If you think our practical experience of model trains over a 50 year + period counts for less than Mr Ames does, you still have a lot to learn about this hobby.
If and when you have any personal dealings with Mr Ames, either in business or technical, you will likely form a more realistic opinion of his competence.
