Okay all you electronic gurus take a look at the schematic on page 2 (page 35 of the actual pamphlet) of this link. http://www.cvpusa.com/doc_center/r11a_G2_manual_color.pdf
Is the diode only there to prevent the gel cell battery from back feeding the rectifier? If there is no battery then a diode would not be needed correct?
Also, I found a capacitor with the same numbers but it doesn’t look the same, it resembles a battery with the wire coming out either end of it.
Does a capacitor have a +/- side to it?
Thanks for the help. these are uncharted waters for me
Terry
because no charging is needed.
