Did You Know...
Late model Accucraft Rubies have electrically insulated wheels! I got my Ruby in January 2020 and had no idea. It is not mentioned anywhere.
I found out quite by accident. My testing and running prove that my wheels are electrically insulated.
I was steaming on our club layout while the track was energized and another club member was running his track powered train and it did not short out the system.
I put an ohm meter to the wheels to confirm the insulated wheels. Meter read infinity.
I set up a piece of track on my work bench and powered it from a bench power supply then put a DC volt meter to the rails with my Ruby on the rails and applied 16 VDC to the rails, and no short.
HUZZAH!
But how did it steam up for you ?
It’s been running great for the past year. That wasn’t the point of this topic though. Running a live steam loco is an entirely different but enjoyable part to large scale model railroading.
I believe the 2-cyl Shay has them too. It has rims that are installed with an epoxy insulator - I suspect your Ruby is the same. Be aware the Shay has been known to overheat the wheels and then the rims fall off. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-cry.gif)
Regner Easy Line locos have insulation in the wheel hubs and (most?) are outside-framed so they are insulated. As long as you don’t tighten the set screws that hold the wheels in gauge too far, and break the screws through the insulation. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-innocent.gif)
I think all Roundhouse Engineering steam locos are insulated.
