So recently a good deal on an Eaglewings Ironcraft engine facility came up that I couldn’t pass up and I purchased it. I gotta say it is an amazing looking building but is a two man lift to move as this one was modified to be slightly longer then the standard building. For those not familiar with it, it can be viewed in following link and is the T-6 building:
http://www.eaglewingsironcraft.com/view_gallery.php?gallery=new&id=5
Seeing as how large it is when I do build my railroad it is going to have to remain outside year round as I do not plan on moving this. That being said I want to detail it up as well as while it is impressive it is still just a large piece of painted metal. As such looking for advice and sounding board here on how to do this. Currently the unit has a flat roof that all around edge and where skylights there is not a solid weld going around meaning water will pour in through the top of this thing. My thoughts to try and solve this I am going to have to seal up the top of the roof and then put in some drain pipes to allow water to drain off. Not sure if there is good sealant that will stick to painted metal to use as a start? To me silicone never seems to fully stick and would still let water in. My next thought is to help water proof and add roof detail is to use something like the following:
https://www.lifesafedirect.com/non-skid-vinyl-tape
Cutting this to run across roof and up the side walls and then sealing seams to create a bit of a bathtub that would then use the drain pipes to channel the water off. Curious of those who have building if they have any take on this? The building is what it is and can’t angle the roof sadly.
