Delton C-16 retrofitted with Aristocraft C-16 Power Block
I know I have seen an article on how to convert the chassis of an Original Delton C-16 to use the Aristocraft C-16 Power Block. I have used the search block here and can’t seem to find it. Can anyone direct me to that article.
Thanks
Dan
Never Mind guys, I found it. It was under C-16 Tips. I managed to modify the Delton Frame so the Aristo Motor Block would fit in it. Cut off the Broken part of the frame where the pilot mounts and added a deck and pilot from a Mikado. Made new domes out of resin turned on the lathe. Well be adding a Pyle Headlight and steam generator as well as two Air Pumps and and an Air tank under the Engineers running board. New Brass Bell and Brass piping will be added with LED lighting in the marker lights, headlight and flickering LEDs in the firebox.
This is going to be a more modern version closer to a C-19 or C-25 than a C-16, but somewhat freelanced as well.
Dan
